Fraction number expression
I got my Degrees to Radian lab done, but the radian indicator shows a decimal values.
Q....              How I can show in the indicator a fractional number not a decimal number?
Q....              How you insert the degree symbol,  the little circle in the top right of the degree value?
Q...               How I  attach a graphic of a XY to my Degree Radian conversion lab that change accordingly with the conversions?
(3,670 Views)
1] Use a Dbl control/indicator instead of Numeric datatype.
2] Use the symbol font & type a small 'o' [NOT Zero], you ll get a small 'o' like that used for a deg symbol.
3] You dont need a XY graph. You can use a simple Waveform graph.
Have fun !
Or, post your code here, somebody ll help.
- Partha ( CLD until Oct 2027 🙂 )
(3,661 Views)
Hi, hope your problem got solved...
Please DONT use the term decimal here. I think you should ve written as integer.
My teammate & I got confused a bit over its meaning.
Please see the links below for their proper meanings.
http://en.wikipedia.org/wiki/Decimal
http://en.wikipedia.org/wiki/Integer
http://en.wikipedia.org/wiki/Fraction_(mathematics)
(3,653 Views)
