Fractional Minute format code
I need to display a graph's x-scale in units of (HH:MM.m), where 'm' is a fractional minute. I found the format code for fractional seconds, %<digit>u, but I can't find one for fractional minutes. Is this possible at all? Maybe I can insert an expression into the format string?
(2,822 Views)
LabVIEW does not support anything but fractional seconds for its timestamp related formatting. If you really want this you would have to create it yourself. Not such a problem for a single frontpanel element but more or less undoable for the scale on a graph or similar control.
Rolf Kalbermatter  My Blog
(2,807 Views)
