Frame size of chain controls
Hi GerdW,
Yes of course.
This VI eliminates the lines above and below the text.
Bruno.
Message 11 of 12
(311 Views)
Hi Bruno,
some simplifications:
No need for local variable and sequence frames. No need to build arrays to detect the BG color…
More suggestions:
  • both loops should be FOR loops
  • DeleteFromArray automatically deletes one entry so doesn't need the "1" constant
  • you can even replace the ("expensive") DeleteFromArray function by just counting "empty" lines in the loops and using ArraySubset after the loops…
Message 12 of 12
(308 Views)
