Framing error on seriell port
I am trying to read data from the seriell port. I doesn't know exactly
the correct setting for communication with the external device, but I
know, I use the correct baud rate.
My problem is, I get from the "Bytes atseriell port.vi" the error 4008h
(framing error). What is the meaning of this error? Any suggestions? I
read 2 bytes more from the port, then I should. This is independent from
the string length.
Regards
Ralf
(3,355 Views)
Ralf Kähler skrev i
meldingsnyheter:3933A000.939782CD@e-technik.uni-rostock.de...
> Hi,
> the string length.
> Regards
> Ralf
Hi
Try to use 'Bytes At Serial Port.VI' and 'Serial Port Init.VI'.
Richard
(3,354 Views)
On Tue, 30 May 2000 13:03:28 +0200, Ralf =?iso-8859-1?Q?K=E4hler?=
>the string length.
You might try to experiment with different types of parity (and maybe
number of stop bits). Do the change of parity with the
Rolf
(3,354 Views)
> >the string length.
> Rolf
Thank's.
I tryed this and so
lved the problem. Another type of parity and 2 stop
bits, this was all.
Ralf
(3,354 Views)
