Free range VIs
Is there a quick way to convert VIs in a library (.llb) to free VIs in a
folder.
I could Save As... but that would be very tedious.
Also, does anyone have any tips for deal with erroneous VI references; I
find it very easy to get LabVIEW confused between different versions of the
same VI. It then saves the top-level VI with a reference to the wrong
sub-VI.
thanks
(4,440 Views)
I just emailed you a vi that will save vi's in a library to vi's in a directory.
hope it helps.
pat
"Nestor Patrikios" wrote:
>Is there a quick way to convert VIs in a library (.llb) to free VIs in a>folder.>I
could Save As... but that would be very tedious.>>Also, does anyone have
any tips for deal with erroneous VI references; I>find it very easy to get
LabVIEW confused between different versions of the>same VI. It then saves
the top-level VI with a reference to the wrong>sub-VI.>>thanks>>
(4,440 Views)
Could I get a copy of that? I'm trying to take control of vi's in
large projects where there are several guys working on several
versions of vi's on different computers on a network. I'd like to
make sure I'm using all the vi's I need from one directory on the
local hdd so I know exactly what versions are being used.
Mike
> hope it helps.
> pat
et
(4,440 Views)
Could I recieve a copy of the vi also?
I really appreciate it, thanks!
-Karl
karl.g.hanke@boeing.com
In article <38A64310.D3E1408D@cruzio.com>,
> Mike
a directory.
> > hope it helps.
> > pat
in a>folder.>I
have
to get
saves
Sent via Deja.com http://www.deja.com/
Before you buy.
(4,440 Views)
Hi There,
You can do it very easily from LabVIEW with no other VIs. Just open all the
top level VI and save each VI with "Save with Option" than select a new location
to save it (be sure to uncheck VI.lib) and than instead of giving a name
move to the directory and hit "Select Cur Dir"
Bye
Andrea
kghanke@my-deja.com wrote:
>Could I recieve a copy of the vi also?>I really appreciate it, thanks!>-Karl>>karl.g.hanke@boeing.com>>>>In
article <38A64310.D3E1408D@cruzio.com>,> Mike Scirocco
wrote:>> Could I get a copy of that? I'm trying to take control of vi's in>>
large projects where there are several guys working on several>> versions
of vi's on different computers on a network. I'd like to>> make sure I'm
eed from one directory on the>> local hdd so I know
exactly what versions are being used.>>>> Mike>>>> patrick sincebaugh wrote:>>
>>> > I just emailed you a vi that will save vi's in a library to vi's in>a
directory.>> > hope it helps.>> >>> > pat>> >>> > "Nestor Patrikios"
wrote:>> > >Is there a quick way to convert VIs in a library (.llb) to free
VIs>in a>folder.>I>> > could Save As... but that would be very tedious.>>Also,
does anyone>have>> > any tips for deal with erroneous VI references; I>find
it very easy>to get>> > LabVIEW confused between different versions of the>same
VI. It then>saves>> > the top-level VI with a reference to the wrong>sub-VI.>>thanks>>>>>>>Sent
via Deja.com http://www.deja.com/>Before you buy.
(4,440 Views)
Under the project menu, there is a file manager.vi that can do this. If
it does not show up under your project menu, search for llbedit.llb.
> folder.
> sub-VI.
> thanks
(4,440 Views)
