Frequency/Continues output using the NIDAQMAX python library
We are pretty much new to this combination of Python and LabVIEW, with the use of the NIDAQMAX python library we want to generate the frequency/continues output with 50% duty cycle(for now).
As suggested in this post nidaqmx co_channels can't write sample we have done the changes but we are not able to generate the output, as this gets executed only once(just one pulse).
 with nidaqmx.Task() as task:
         task.co_channels.add_co_pulse_chan_time(counter="Dev5/ctr3", low_time=0.005,high_time=0.005)
         task.start()
If i put the for loop, with this we are able to generate, but we don't having any control over the frequency and number of samples are finite only.
for i in range(10000):
                   task.start()
Our aim is to convert the LabVIEW code in the below screenshot into Python, with out the use of while/for loop (this is because once we set the FO, we want to pole DI/AI and based on that we would like to set AO/DO's)
NI PXI-6602
Python 2.7
LabVIEW 2013 SP1 32-bit
OS: Win7, 64-bit
Regards
Anup S K
Message 1 of 1
(2,489 Views)
