Frequency Question
I am trying to make a frequency measurement. I have a lab-pc-1200 NI card
that I am using with Labview 4. When I try to run the Counter - How to
measure Freq. and period VI, I get the following error:
Error 10403 occurred at CTR Group config. The specified device does not
support the requested action.
Does the 1200 DAQ support this or why am I getting this error. I would
assume that I should be able to connect the signal to the Gate B1 port and
read the frequency.
TIA
(3,308 Views)
Be sure that you are not using counter VI's which are intended for E-series boards with DAQ-STC counters. The 1200 DAQ does not have these counters, so the NI-DAQ software will return this type of error.
Mark
(3,308 Views)
Is there a VI for the 1200 boards? What is it called?
Darren
"markwysong" wrote in message
news:506500000005000000C26B0000-1017707437000@exchange.ni.com...
> Mark
(3,308 Views)
Darren,
On your diagram, right click and look under Functions->Data Acquisition->Counter->AM9513 & 8253 Compatibility. There are many VIs in there that you can use for the counters on this board. The 1200 contains 3 16-bit counters, and they are of type 8253, so these are the ones you need to use.
Mark
(3,308 Views)
