Hello Wayne,
Your application sounds like a fairly typical frequency response application such as measuring the response or transfer function of a filter. In this case your tuned circuit is behaving like a filter. There are many examples of these types of application using LabVIEW. One of the standard examples in LbVIEW is a frequency response measurement. You can find this example in the following location.
..\National Instruments\LabVIEW 7.0\examples\apps\freqresp.llb
Of course the interface for the signal generator and measurement device will need to be adapted to your hardware.
You can also find several other similar examples in the Developer Zone library.
Frequency Response (step response method)System Simulation SandboxFrequency Response using Swept SineChristian L
authored byChristian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
