Frequency Response Function NxM output format
When the Frequency Response Function for magnitude, phase, and coherence
is used in the NxM "all cross pairs" polymorphism, the format of the outputs
are still 1-D arrays of clusters instead of a 2-D NxM sized array of clusters.
Does anyone know how the indexing of this 1-D array would correspond to
indexing of the would be 2-D array?  Or is it just [index/M, index%M].
Kevin
(2,842 Views)
Hi Kevin,
First, thanks for posting this request.  You've helped us find a gap in our context help.  The documentation on X-Y pairing should be improved and the VI documentation should be extended to cover all instances of this polymorphic VI.  Here is some text that should be added to the "X-Y pairing" description:
"all cross pairs" means that the pairs are formed by matching each signal from array X with ALL signals from array Y, continuing in this fashion for each signal in X. If there are N signals in X and M signals in Y, the total number of cross pairs is N x M. The paired signal results Xchan-Ychan are returned in the order 1-1, ... 1-M, 2-1, ... 2-M, ... N-M. "
Hope this helps,
Mike C
LabVIEW Math & Signal Processing
(2,824 Views)
