Frequency Response Function & FFT & Inverse FFT (problem of unit Volts-RMS)
Hello everyone,
I am currently working on a VI in order to compare two analog signals : the first one corresponds to the output signal (my reference) which is sent by my data acquisition card to a shaker and the second one corresponds to the input signal recorded by an accelerometer fixed on the same shaker. The final goal of the VI is to correct the analog output signal by using the analog input recorded signal in order to have the vibrations on the shaker which corresponds to what we really want.
To summary, I have a problem of unit with the Volts-RMS...
So this is my method for the VI :
First, I have to calculate the Frequency Response Function between the two analog signals (output and input). For it, I use the " Frequency Response Function (Real-Im).vi " which returns the complex values of the FRF in Volts-RMS (but I don't want to use this unit).
Then, I want to calculate the FFT of the analog output signal (my reference). There are two different blocs which can be used : " FFT Spectrum (Real-Im).vi " and " FFT.vi ".
The " FFT Spectrum (Real-Im).vi " returns the FFT complex values of the signal in Volts-RMS and the " FFT.vi " returns the FFT complex values in Volts (or say me if I am wrong, thank you). I really would like to use the second one because of the unit.
Then, I divide the FFT just calculated with the Frequency Response Function calculated just before.
For the end, I calculate the inverse FFT of that with the " Inverse FFT.vi " which use the complex values with the same unit than for the " FFT.vi ".
I don't want to use the Volts-RMS unit because I absolutly want to use the blocs " FFT.vi " and " Inverse FFT.vi ".
The problem is that I don't find a bloc which use the same unit for the Frequency Response Function. The " Frequency Response Function (Real-Im).vi " returns only the complex values in Volts-RMS unit. Maybe it is possible to convert it correctly? Or maybe there is an other bloc which can be used in order to calculate the Frequency Response Function with the same init than for the FFT and Inverse FFT ? Because I can't mix everything for the moment...
Thank you for your help,
Sebastien
(3,820 Views)
Are you using the Sound and Vibration toolkit?  These tools deal with all the unit conversion.
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(3,803 Views)
Hello Preston,
No, I have not use the Sound and Vibration toolkit. I have only used the signal processing toolkit with the two toolboxes " Waveform measurement " and " Transforms ".
But I think that what I have done for the moment in my VI is correct (I have finished the complete VI). But I am not sure of the units (Volts, Volts-RMS...) and I would like to understand.
I have tried with the Sound and Vibration toolkit for the frequency response function (because you say me that it deals with all the unit conversion) and I can obtain the same results than with the " Frequency Response Function.vi " of the toolbox " Waveform measurement ".
But I would like to understand the units (see my previous post please). For example, for the FFT (the result is a complex), why sometimes it is in Volts, sometimes it is in Volts-RMS ? Is it possible to convert it ? How ?
If you want, I can attach on the forum my VI and that will maybe help you to explain me. Maybe it will help other people interested.
And if someone else can give me other precisions or advices about it, do not hesitate.
Sebastien
(3,784 Views)
