Frequency measurement not timing out 9401 board
Hello, I am using a cDAQ-9181 with a cDAQ 9401 board. I created a task in max for counter 0 to read frequency with the following settings
Signal input range
Min 2 Hz
Max 50kHz
Starting Edge Rising
1 counter(low frequency)
1 Sample (On Demand)
I need to aquire this frequency every 10 ms so I tell it to time out at 0
I have an input frequency of 5Vpp sweeping from 1 to 40kHz rising time of 30Sec and Return Time of  30sec so the whole wave takes about a minute.
It works fine for a while but every now and then it pauses for about 250ms and I believed it should time out but it doesn't return an error. Is there another setting that I need to set up for it to time out or this is hardware related and there isn't much I can do but to wait?
I have attached the vi that comes with labview and updated it to show what is happening.
I would appreciate some help thanks
(2,358 Views)
Hey Bertha,
This isn't the correct forum to post to. This topic belongs in the Multifunction DAQ section. Feel free to repost this here
Kurt P
Automated Test Software R&D
(2,328 Views)
