Frequency measurement
I modified the examples "Count and period - crio" to measure the frequency of a digital signal. The frequency measured (about 42.4 Hz) is 4 time higher then the input (about 10.6 Hz).  Is an error in my program?
I use the module 9411 on a 9104 with the 9012.
Daniel
(3,704 Views)
Perhaps the input signal has jitter on it? If you put a wait inside the upper true case (when the edge is > that the previous), for instance 10 ticks, the jitter will be ignored.
Wiebe.
(3,651 Views)
dboulay:
Feel free to post again if you are still experiencing issues.
Rudi N.
(3,624 Views)
Message Edited by Rudi N on 05-08-2007 06:57 PM
(3,625 Views)
Message Edited by Rudi N on 05-08-2007 06:58 PM
(3,626 Views)
