Frequency to Voltage with NI 6002
Hi all
I am having a color sensor that outputs a Frequency in kHz that quantifies a particular color, when a LED is switched on. ( For e.g Red gives 12 kHz; Green  8  kHz and Blue gives 5  kHz)
At first i was planning to use a Freq to Voltage converter  (like LM2907) and the obtain voltage. But since i already have a NI 6002 box for another purpose in the same project, i was thinking whether i can i wire the sensor output directly to Analog Input of NI 6002 and get a reading/result ? Or would it be better to use Freq to Voltage converter and then proceed?
Nghtcwrlr
(3,191 Views)
Accepted by topic author Nghtcrwlr
You have two options,
Use the counter to measure the frequency, see examples (and MAX/DAQ assistant on how to wire)
Or capture the voltage as an analog signal with a AI and use the tone detection vi.
If the output is in a range that fits to the digital input, I would use the counter.
Greetings from Germany
Henrik
LV since v3.1
(3,146 Views)
Hi Henrik,
Yes, I used the counter to measure frequency. it works well.
Nghtcwrlr
(3,063 Views)
