Friends Relationship between two distinct .lvlibp
Hi everyone,
I have some troubles implementing friends Relationship for two seperate packed library.
I have 2 seperate library : "X.lvlib" and "Y.lvlib"
Each of them containing respectively 1 class : "X.lvclass" and "Y.lvclass"
Each of them belongs to 2 seperate projects : "X.lvproj" and "Y.lvproj"
I want to use "Y1.vi" part of "Y.lvclass" into "X1.vi" part of "X.lvclass" so :
  1. I define "Y1.vi" as community scope access
  2. I define "X1.vi" as public scope access
  3. I define into "Y.lvclass" the class "X.lvclass" as a friend
In the source code, I'm able to call "Y1.vi" into "X1.vi".
I'm able to compile the packed libraries "X.lvlibp" and "Y.lvlibp"
When it comes to use the "X1.lvlib", I get an error like the "Y1.vi" is not executable.
I am able to have things running when I put both classes in the same library, I mean "X.lvclass" and "Y.lvclass" in a unique Library "Z.lvlib".
My problem is, I need the classes to be in 2 seperate library for the code organization, however I want to control the classes or VIs, like for instance "X.lvclass", that have ability to call the "Y.class" VIs, defining friends relationship.
Thanks in advance for your support
(2,717 Views)
Hello Gardy_BIVARD,
I would try defining into the library "Y.lvlib" the class "X.lvclass" as a friend.
All the best,
(2,680 Views)
