Hi pathman,
Can you provide us with more details? If your vi worked in LV6, it should (in theory) work with LV7.
You have a Hioki Impedance Meter, right? What do you mean by "modified impedancemeasurement.vi"?
The first thing is: how do you communicate with the instrument? (GPIB, serial, other?)
Can you define what you mean by incorrect result and "not working"?
If you didn;t get an error message, do you mean that it ran, made measurements, completed it's task (vi) and provided measurement values without giving you an error? That would mean that it is working but could provide incorrect results....
So:
1. Can you communicate with the instrument?
2. Does the vi run?
3. Does the vi make measurements from the instrument?
4. Incorr
ect results. What type of results are you getting?
The more info we have, the easier it will be to help you.
JLV
