From Vision assistant to VI problem
Hello
I'm trying find couple of edges from an image in LabView. I have created Vision Assistant block in LabView. In the Vision Assistant I use the Straight Edge (Rake) tool from Machine Vision Tab. The inspections works just as I liked it to work. After I have selected controls and pressed finnish, Labview starts to create theLabView Vi from the Vision Assistant. After a while the creation stoppes and the LabView askes me to find the IMAQ Find Horizontal Edge or IMAQ Find Vertical Edge VIs. I have tried to look them from all the library files and tried to google it but I cant find either of those VIs. I have tried to create the program on two different computers.
I have opened the front panel of the vision assistant block and replaced the IMAQ Find Horizontal Edge with Vision and motion -> Machine Vision -> Locate Edge -> IMAQ Find Edge too. The Find Edge tool has totaly different inputs than the Find Horizontal Edge tool so this isn't working.
Can some one tell me what do to make this work?
Mikko Remes
(3,758 Views)
Just to check whether you have installed vdm properly. Do you see this?
(3,745 Views)
Here is part of the LabView generated code where the IMAQ Find Horizontal Edge should be. And yes I see the Vision and motion tools.
(3,739 Views)
I found the IMAQ Find Horizontal/Vertical Edge tool. They were in the Compatibility.llb. I didn't notice them at the first glance. Can some one tell me how to add library files to the labview so that I don't have to browse the librarys every time I change the Vision Assistant file?
(3,720 Views)
