From dynamic data to string
I would like to convert my dynamic data (4 channels and time) to sink of string (I am using UDP Write).
I tried to build an array, and then use Nnmber to fractionnal string, but I can't wire the two, because it's 1D array of string.
Thanks for your help!
Sarah
Images intégrées 1
(6,033 Views)
Use a for loop, input the array of numbers as auto-indexed, input that to the convert function, and output the result as an auto-indexed tunnel. The result will be an array of strings.
(6,028 Views)
It is already in a for loop. And the input of the UDP is a sink of string..
And I don't know what is an auto-indexed tunnel
(6,024 Views)
Accepted by topic author sarahdan
did you check Array To Spreadsheet String Function
(6,016 Views)
Attach your VI.
And if you don't know what is an auto-indexed tunnel, then take the tutorials.
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
(6,010 Views)
sarahdan wrote:  I am using UDP Write
And what is recieving the data on the other side?  Another LabVIEW program?  A microcontroller?
(6,001 Views)
