From hex to jpeg.
Hello.
I'm trying to generate a JPEG picture from a hexadecimal textfile ultimatly directly from a serial port, and I'm alittle stuck on the execution.
After some googeling I think I've understood that you need to arrange the hexadecimals in an array and then generate the picture.
But doing so only generates a almost black picture with som white dots, so something is very wrong.
Could anyone give alittle heads up to what I may be doing wrong?
I've attached the file with the picture in hex.
Thanks in advance,
ASibbern
(5,745 Views)
I had the same problem once.
I made a VI that captured a waveform from an oscilloscope. The problem was that during the transmission some extra bits, at the beginning were added.
I did the following:
- changed the capture format to a format that can be easily interpreted (bmp or tiff)
- capture the waveform and compare it to the standard file (from your PC)
- remove extra characters and try it again with jpeg
Personally, I prefer TIFF - because it's easy and fast to read the tags. Capture as tiff and compare what you get with a tiff from your PC. I think that the first information from a tiff is little endian or big endian (search on google how exactly starts tiff or bmp files).
Paul
(5,734 Views)
on more thing: write it in binary form not as text.
(5,730 Views)
Hi ASibbern,
the attached example shows how it could work. It shows how you can create your image from the txt file. If you show us your code, maybe we will find a simpler solution to write the image directly.
Mike
(5,724 Views)
Thank you
I am connected to a JPEG color cam with a serial port,
so the first part is just taking picture.
i wish to stream it like a video
(5,715 Views)
