From little Endian to big Endian
Hi guys, Is there a function in LabView 2010 to go from little endian to big endian? I want to change for example 'B0011000' to '001001B0'.
Message 1 of 10
(19,820 Views)
Yes, you do have that, here is the path to access it in the palette (my LabVIEW is 8.6 so the palette might be slightly different to yours) :
You have a "swap byte function", "swap words", "split", "join", etc...
Everything you need 🙂
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 2 of 10
(19,818 Views)
Hi TiTOU
I had the same problem, and your solution is not working for HEX number, do you have another solution, thanks in advance
Regards
Alhaidar
Message 3 of 10
(19,369 Views)
Using the swap bytes and swap words functions on a U32 will do what the original poster asked.
Are you working with a number (blue wire) or a string (pink wire)?
Message 4 of 10
(19,360 Views)
Hello freinds
i found one sulution for 4 byte (if more/less add/delete replace substring blocks) .... if you have better one please share it ...
Regards
Alhaidar
Message 5 of 10
(19,353 Views)
how about this
Labview user
Message 6 of 10
(19,347 Views)
thanks PhillipBrooks
but I'm getting data form sensor as string (Pink wire), more Info see my last replay.
Regards
Alhaidar
Message 7 of 10
(19,346 Views)
You could do this.
Of course this only works correctly if the string length is even.
Message 8 of 10
(19,337 Views)
Combining a couple of these approaches into one that's a bit more reliable. It works for any length string that contains an integer number of 32-bit values; if you're dealing with 16-bit values, change the representation in the array.  LabVIEW is natively big-endian so this code reverses endianness.
Message 9 of 10
(19,294 Views)
Assuming this is about the 4 byte sensor data only (which is actually a strange way to send in wrong endian order anyhow) I would think this is the most direct conversion. I prefer to convert string numbers into real numbers as soon as possible in a program. Makes things much easier to work with.
Rolf Kalbermatter  My Blog
Message 10 of 10
(19,270 Views)
