Front Panel Binding Mass Configurator does not work with VIT's
The Front Panel Binding Mass Configurator does not seem to work with VIT's.  It works fine with a .vi file but when saved as a .vit it doesn't show any controls in the Binding Configuration list.
Is this behaviour by design or is it a bug?  Is there a way around it? Can anyone help?
(2,551 Views)
The problem is that you are working with template VIs. Binding the controls of a template doesn't make sense because in a sense you can't run a template. As soon as you open it LV generates a logically independent copy or clone of the original. Now say you bound a control on the template and then opened 3 copies of it - which one of the three should really exhibit the binding?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,544 Views)
