11-29-2022 11:40 AM
I have a decent sized control sequence that utilizes many sub VIs. Some of the subVIs are used several times and the front panel from the subVIs are displaying information. The issue I am having is that because the subVI is called in multiple different places, I need to open each instance of the front panel to see the information. Is there a way that I can have only one front panel open that updates each time any of those subVIs are run?
11-29-2022 11:43 AM
Make the subVI non-reentrant (which is the default).
Your questions is too vague in general. Can you describe the project in more detail?
11-29-2022 11:56 AM
Here is a picture, hopefully is clarifies!
11-29-2022 12:05 PM
Truncated code pictures never clarify much.
11-29-2022 02:20 PM
@KeplerRidge wrote:
utilizes many sub VIs ... the subVIs ... front panel [of] the subVIs are displaying information....
Sound like you need to put the sub-vi's into your top level vi as a sub-panel.
