Front Panel Terminal 'Tab Control': unwired front panel terminal
Hi All,
I got this Block Diagram warning and it's the only thing LabView is complaining about my VI.
I am using a tab control on the front panel and it's been there for a few month but this just popped up yesterday.
Can anyone give some suggestion here?  I repaired the LabView 8.2 and Device Drivers already.......
hellolv
(3,616 Views)
Hi, don't be afraid of this, it's only a warning. It says that the VI runs, but perhaps you have something forgotten. Since you use the tab only to switch the visibility of some front panel controls/indicators, all is fine.
The message came up because you checked the "show warnings"- checkbox.
Greets, Dave
Greets, Dave
(3,613 Views)
DaveTW,
Thanks for your response.  But my VI doesn't run even with the Show Warnings box unchecked, so it's kind of a problem I guess.
hellolv
(3,604 Views)
OK, I agree with you, this is a problem... Smiley Sad
It seems that the VI got corrupted and you have to replace the tab control with a new one.
Greets, Dave
Greets, Dave
(3,597 Views)
