Front Panel symbol palette for industrial process equipment
Is there Front Panel graphic symbol palette for industrial process equipment for LabView, such as symbols for motors, heat exchangers, pumps, valves, tanks, etc., similar to that which was available with BridgeView?
(3,547 Views)
Accepted by topic author nightwind
If you have the Datalogging and Supervisory Control (DSC) Module you will have those controls and indicators.  The DSC module is what replaced BridgeVIEW.
(3,542 Views)
Thanks for responding.  Yes, I've just installed LabView 2011 with the DSC module.  On your suggestion I started looking on the Front Panel and finally found what I was looking for under "Tools/DSC Module/Image Navigator".
thanks again, and I very much appreciate the response
(3,527 Views)
