Front panel binding on the RT
Can I use front panel binding to network shared variable on RT (cRio 9012)?
(3,644 Views)
Hi gresT,
You can use front panel data binding with any network shared variables, but it is not recommended with LabVIEW Real-Time because the front panel may not be present.
Using the LabVIEW Shared Variable
(3,595 Views)
