Front panel class objects are missing their icons in the runtime engine
I have this project that contain some class objects. When run in the developer environment, the icons appear fine.
However when I build as an executable and run it in the runtime engine, the icons are missing.
These missing icons are purely cosmetic and the underlying logic works without a problem. Is there anyway to get these icons to display when built as an executable?
(2,681 Views)
Known issue, see http://lavag.org/topic/12980-class-control-icon-not-shown-in-run-time/
EDIT: have you considered just making that control invisible?  Takes a bit of manipulation of property nodes and references but you can do it as shown:
(2,676 Views)
