Front panel cursor hand only
On the front panel I only see the hand cursor.  I can place objects but not edit or move them.  On the block diagram I can place objects but not wire or move the objects.  The VI is not running.  I am using LabView 6.1.
(5,022 Views)
I don't remember if version 6 had auto tool select. If not, try pressing the tab control or space bar. I think auto tool select was added in 7.x
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(5,013 Views)
Accepted by topic author JohnP
You do realize, don't you, that you have to manually select the tool with 6.1? Can you show the Tools palette to select from? Can you click on the tab key to cycle through the tools?
(5,012 Views)
