Front panel dial control
I have a 10 turn K precision potentiometer that has a dial counter knob with a range of 0 to 10 with a precision control to a 100th of a turn. The potentiometer is wired to a +/- 15 VDC power supply so that when at position 5 the output is 0, at position 0 the output is -15 VDC and at position 10 the output is +15 VDC. I am trying to simulate this using a dial control but I can not figure out how to get the scale to represent the turns of the potentiometer and the output to range from -15 to +15 VDC. I am sure that this can be done but I just can't see how, if anyone can point me in the right direction I would appreciate it. Thank You.
(3,646 Views)
Is this close to what you were hoping for?
(3,641 Views)
It sure will, thank you. I knew it was something simple that I was overlooking. Thanks again.
(3,637 Views)
