Front panel gone
When working with labview 2010 I managed to screw up the front panel, now it must be expanded each time I open it, and some of the indicators are huge.
Is there a way to either get this back or go back a step in history?
Joel
(3,077 Views)
Accepted by topic author truckryder
Never mind, it's fixed, I don't know what I did, but that was a wasted hour of my life!
(3,074 Views)
You accidentally checked Scale Object with Pane from the right click menu-  un check it.  also, revert to default widow apperance from VI properties and you'll be good to go
(3,072 Views)
Sweet, now at least I know what I did wrong.
Joel
(3,061 Views)
