Front panel indicators
I have an indicator that shows the pressure limits of my system. These represent 3 channels each attached to a pressure transducer:
Is it possible that it changes the colour at a defined value? For example:  for one of the three pressure sensors in my picture, the max. pressure is 440 bar (I didnt change that in the picture). Can the fill be green from 0 - 350 bar, then turn orange from 350 - 400 bar and finally turn red for 400 – 440 bar?
Message 1 of 10
(3,736 Views)
Hi erabrannan,
Yes.
Spoiler
That's what properties are good for!
Message 2 of 10
(3,731 Views)
how would I do that so it changes it just for one pressure transducer and not all 3?
because each transducer has their own limit.
Message 3 of 10
(3,720 Views)
Hi erabrannan,
the simple rule applies: in an array all elements share the same properties!
The answer is: don't use an array!
Use 3 scalar elements, or a cluster of 3 elements…
Message 4 of 10
(3,715 Views)
Yes, true!
so in my code I tried this:
what I was thinking here is I will make the fill turn green only if the value is greater than 20. But there seems to be a clash between boolean and the numeric indicator.
How would I do that?
Message 5 of 10
(3,704 Views)
@erabrannan wrote:
Yes, true!
You're Close. In this case you can add a Select after the Greater than and wire two colors needed through that. One 'normal' color and one for when it's >20.
You're only thinking of "What should happen when it's >20", but missing the thought of "What should happen when it's <=20". That's what the Select is for.
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 10
(3,693 Views)
how do you wire the colour box to the condition of greater than?
-Emilie
Message 7 of 10
(3,661 Views)
hi,
thanks to your help I managed to get it to work with one element. But how would I do this with a 1D array? (picture of the first post)
-Emilie.
Message 8 of 10
(3,657 Views)
Hi Emilie,
Did you read my first answer?
I hate to repeat:
In an array all elements share the same properties!
Solution: Don't use an array, use scalar elements or cluster of elements!
Message 9 of 10
(3,653 Views)
As said, you can't have individual color in an Array. You can change to a e.g. a Gauge and have a gradient, though that solution only works if you have the same limits.
So, to change colors of slider inside a Cluster, get the references of the sliders and change them via properties.
Qestit Systems
Message 10 of 10
(3,631 Views)
