Front panel invisible?
Does anyone knows: is it possible to make running top-level vi with front
panel invisible?
I need to run my vi's in embedded Linux environment - so it is impossible to
put GUI libraries in FLASH-disk (16-32 Mbyte total).
(3,570 Views)
Hi Sergey
> panel invisible?
There is an article about that in the sample issue of the Labview
Technical Resource. You can dl it from http://www.ltrpub.com .
Best wishes,
Rado
(3,570 Views)
go to ni - developer zone site
and search in Labview> advance programming technique>general, there is a
example code about windows utilities (32 bit). They have very useful feature
you want.
if you can't find it, email me and I will send it to you.
"Sergey Yakovlev" wrote:
>Does anyone knows: is it possible to make running top-level vi with front>panel
invisible?>I need to run my vi's in embedded Linux environment - so it is
impossible to>put GUI libraries in FLASH-disk (16-32 Mbyte total).>>>>
(3,570 Views)
