Front panel precidence
Is there any way to "sneak" a picture ring indicator behind already
present control buttons?
I know that if the picture ring indicator is placed first on the front
panel that other controls and indicators can be later placed on it, but
this is an existing vi with a number of controls already
on the front panel. Now if I place the picture ring indicator on the
front panel it covers up the buttons.
All of the buttons have extensive wiring to attribute nodes so that
deleting and replacing them would be a lot of work.
Bill Lubarsky
(2,799 Views)
You should be able to highlight the desired control and select "Move to
Back" from the tool bar menu bar reorder pick list. Or use Ctrl-Shift-J.
Hope this works.
-Tom
blubarsky wrote in message
news:3A664925.3CB1665B@snet.net...
a lot of work.
> Bill Lubarsky
(2,799 Views)
There's a little icon at the right side of the toolbar. It's called reorder.
blubarsky wrote:
>Is there any way to "sneak" a picture ring indicator behind already>present
control buttons?>>I know that if the picture ring indicator is placed first
on the front>panel that other controls and indicators can be later placed
on it, but>this is an existing vi with a number of controls already>on the
front panel. Now if I place the picture ring indicator on the>front panel
it covers up the buttons.>>All of the buttons have extensive wiring to attribute
nodes so that>deleting and replacing them would be a lot of work.>>Bill
Lubarsky>>
(2,799 Views)
