Frontpanel element design
Hey guys,
I use LabVIEW 2017 and I wanted to pimp up my frontpanel. I dont want to use the "silver", "classic" or "system" designs. I mainly use vertical slider elements and a few other standard input elements for numbers.
I remember once, that I downloaded some fancy element layouts from VIPM. But I cant remember the name and "google" was not my friend so far.
Does someone of you know some "libraries", or whatever the design packages are called, I could try?
Thank you guys.
(6,595 Views)
Accepted by topic author Slev1n
(6,582 Views)
i am still on LV2016 but ones in my VIPM:
  • JKI Flat UI Controls
  • OpenG Buttons Library
  • UI Control Suite: Metallic Theme
  • UI Control Suite: NI Themed Custom Control Suite
  • UI Control Suite: System Controls 2.0
another option is to build you own for example with XControls but that is involved.
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(6,581 Views)
Thank you guys so far, I am going to check them, but I think the "Flat UI Controls" was what I was using previously.
(6,520 Views)
(6,496 Views)
The problem I come across quite often is that the control sets are incomplete.
So you'll be designing a nice consistent UI and then have to revert to another set for a particular control. Smiley Mad
(6,486 Views)
