Ftp via system command pipe. Is it possible?
Hi.
Im programming a small interface between a machine with a ftp server and a linux machine with a database.
To get the file from the ftp machine I thought I would open a system command pipe to ftp and then just do as I would've done from the command prompt.
This is not working however. Ive made a small example.
I open the pipe and wait for 1 sec. then countinue to write: "open localhost<enter>"  to the pipe. The reply from the pipe is nothing. And it should be something like: "Username: ".
What am I doing wrong, or is the system command pipe simply not working as I expect or as it should?
Attaching a example of what I am doing. (I am running a ftp on my local machine for testing).
//Beckman
(3,433 Views)
hi there
if you are on a windows platform you also can use the DataSocket Read/Write functions to receive/send data from/to ftp. see the online documentation or search this forum for more information.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,431 Views)
Hi.
Yeah. I should've made it more clear that I'm programming on a linux system.
Cheers
Beckman
(3,430 Views)
hi there
i still have LV7.1. maybe 8 can do ftp-ing with DataSocket functions on linux systems.
Best regards
chris
(3,421 Views)
Hi again.
Ive just completed a small ftp-client with the use of the tcp-vi:s that are included in labview.
However I still would've liked if the system command pipe would've worked.
Cheers.
//Beckman
(3,416 Views)
