Full duplex communication using VISA
I got your point and may be my VISA is not working properly but VISA write is generating error
Message 11 of 19
(1,784 Views)
Hi Rajesh,
                 I don't understand your VIs completely.You used VISA Read in both the VIs??After sending the command there is no indication in the receiver such as a command is received.Anyway I will try it in my VI.
Thank you.
Thanks as kudos only:)
Message 12 of 19
(1,763 Views)
Hi Rajesh,
                One point to note about your VI is, the string indicator in the Sender.vi is displaying nothing in true cases also.That is at the time of button click it has to display TRUE.Here it is displaying nothing.So I think in this case the Read operation in sender.vi is not working properly.
Message 13 of 19
(1,744 Views)
     I tried using single resource.Data reading and writing is working properly.And in the data receive.vi,on button click it is displaying command and the "write count" indicates that the write operation is working properly.But reading is not taking place in data send.vi,"return count" is not displaying anything.How to correct the attached VI?How to make both operations to happen simultaneously??
Message 14 of 19
(1,715 Views)
Perhaps VISA close is called too often?
I hope a partial suggestion is better than none.
Here's kind of how I would start:
Message 15 of 19
(1,710 Views)
You can try something like this. I have not tested it, you can use the same vi in both the places.
Message 16 of 19
(1,705 Views)
Hi Todd,
            sorry!can you please tell me,is the attached png is the data receive.vi?
Hi Anand,
                The code seems not reading the array values.
Message 17 of 19
(1,692 Views)
@danil33 wrote:
Hi Anand,
Not reading the array value means?. Can you show me how you have edited the code.
Message 18 of 19
(1,688 Views)
Hi Anand,
              Sorry for late reply.I did the code like this.when I first executed the VIs it can read the values from the other VI.Then I stopped the VIs and again executed, the VI can run only momenterly and stops immedietly.Not even get the time to press write button.
Message 19 of 19
(1,660 Views)
