Full information about DAQmx Task Name - How get?
Labview 7.1 (information required for solve problem)
I put in my application a DAQmx Task Name for fast configuration but i want put all information about task in a txt or spreadsheet file. But in Labview 7.1 haven't VIs like (http://zone.ni.com/devzone/cda/tut/p/id/3079😞
- DAQmx Info Query
- General DAQmx channel Info
- General DAQmx TEDS Info
I'm using Analog Input (Voltage and Accelerometers) with several configurations and I need register all data of configuration to re-execute in the future or know about how acquisition data were gotten.
I think that solve is in property nodes(DAQmx Task, DAQmx Channel, DAQmx Timing), but I believe will be hard work to make. Somebody has this working?
Leonardo de S. Cavadas
Maintenance Engineer and Inspection - Bureau Veritas do Brasil
Engineer Metallurgist with emphasis in Advanced Materials
Technologist in Computer Science
(4,407 Views)
Hi Leonardo,
Sorry about not getting back to you earlier. Have you double-checked the page you've linked in your post? In the bottom of the page there is the link where you can download all the VIs that will do the job for you. They get all the info from any task you select, prepare the info for the TDM format and save the TDM file so you can retrieve each detail from any task saved.
Hope you find this information helpful.
Regards
Andre Pereira
Applications Engineering
(4,362 Views)
Dear Andre,
thx for your help, but in start of my post i say that i have Labview 7.1 and this examples don't run in 7.1, only in 8....because this i look for help in Forum. If yu help me with example in 7.1 version I will be happy.
Thx for all.
(4,344 Views)
Sorry about that, I haven't checked if they were made only for LV 8 and later. Attached is a zip file with all the VIs converted to the version 7.1.
Some of them were not successfully converted and are presenting fatal errors when opening, probably because they have something not available in 7.1. But I'm sending you anyways, because the three VIs you mentioned in your first post that you wanted, are working fine in LabVIEW 7.1.
- DAQmx Info Query
Please let me know if this is of any help for you or if I can do anything else in this case.
Best Regards
Andre Pereira
(4,338 Views)
Great....thx Andre....for all.
(4,290 Views)
