Fun VI
Hello everybody!
Could anybody help to explain this VI.
Sorry, but I realy don't understand it!
Thank you.
p.s: The VI is attached
(3,741 Views)
What do you want to know exactly?
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,724 Views)
Hello!
I want to know the programming of the phasor and of the nummer which is falling down!
I hope you can help me.
Thank for your quick answer.
Aiche
(3,720 Views)
Just resize the while-loop (upper-left corner direction) and you see a part of the code. The rest must be hidden in the same way (different layers, resized loops,...).
The falling needle is a separate control, hiding its scale with a white ramp. The Meter-Indicator has a transparent needle. So you see the scale of one control and the needle of another.
Over the numeric indicator are two string indicators (one for "normal" counting and one for the falling number). The falling number is just a string indicator which is moved in each iteration.
Just try to debug the vi in highlighting mode and you can see some values moving somewhere behind the visible loop.
Hope you understand it now.
Thomas
Using LV8.0
(3,717 Views)
Hi Aiche
If want to see all the code, right click on any border of for loop and while loop and mark "auto groww".
All code will be visible.
There is, too, and untitled.vi. See vi hierachy.
Greetings.
Alipio
"Qod natura non dat, Salmantica non praestat"
(3,689 Views)
There is no Untitled.vi used in Spass.vi The vi in the hirearchy must be in memory but it is not tied to Spass.vi
(3,655 Views)
