Function Generator to check phase sync between two AI channels
Is there any way to connect a function generator or with an oscilloscope with a NI module to see whether the sinewave graphs of two analog input channels are not loosing phase for sync purposes? For this LabVIEW 2014 will be used to generate the code.
Thanks.
Pepis21
(3,369 Views)
Are you already acquiring this data with NI hardware and LabVIEW?
If not, then I would suggest picking out an Analog Input module that best suits your needs!
http://sine.ni.com/np/app/main/p/bot/no/ap/daq/lang/en/pg/1/sn/n25:device,n36:19,n17:daq/
Once you have that, you can bring the data into LabVIEW and use a VI such as Extract Single Tone Information to read the phase of the two signals and determine the difference.
(3,189 Views)
