Function of the further Programms when I use LabVIEW PDA
I write my Bachelor Thesis over a PDA Application where I´ve create with LabVIEW PDA.
Before I could use the LabVIEW PDA I must install few programms.
1)VisualStudio 2005 Standard
2)Visual Studio 2005 Command Shell
3)Windows Mobile 5.0 SDK for Pocket PC
4)eMbedded Visual C++ 4.0
5)eMbedded Visual C++ 4.0 SP 4
Anybody knows what functions this Programms have? I don't need it for the whole time.
Thanks for your answer
capunze
Message Edited by capunze on 05-16-2006 10:40 AM
(2,476 Views)
The way I understand it (I don't have any official knowledge, and I wouldn't mind hearing an explanation either), LV PDA converts its code into C code and then uses eVC to compile the code for the PDA. I assume you're using LV 8.0 because Visual Studio wasn't required in previous versions. Maybe it's also needed now in order to compile the code.
___________________
Try to take over the world!
(2,466 Views)
