Functional Global - While/For Loop
Hi Ppl,
I recently came across a functional global implemented with a for loop wired with a 1 to the count terminal. I have been moslty using the while loop wired with a TRUE, and some times using the Feed back nodes for implementing the functional globals. Are there any performance improvements for functiosnla globals while using For Loops ?
Sathish
(3,720 Views)
It's a matter of taste. It shouldn't be any difference in performance. When writing text based programs i much prefer for-loops to while. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,711 Views)
I remember reading (I can't find the link) that a for loop is slightly more efficient than a while loop for a FGV, because the compiler knows the for loop termination criteria before it runs, and so is able to reserve any resources which may be required. As opposed to a while loop which evaluates its termination after the loop has run each iteration, and needs to request resources on the fly.
Although I was always under the impresion that a for loop gets converted to a while loop by the pre-comp.
_____________________________
- Cheers, Ed
(3,692 Views)
I think for developement reason it's better to use a while loop, cause it's more flexible.
Bjorn
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(3,676 Views)
