Functional global set as reentrant vi in CLD sample?
Hi Everybody,
Thank you for all those clarifications.
I think the first aim of the post was to show that there were a "bug" in the CLD Training solutions.
I think people use those solutions to evaluate their own trainings (at least I did), and to find new (or better) implementations and tricks that they usually use.
Even if those solutions are taken from customer's examination solutions, I think Grading team should have a better look at it, and probably a little of rework before.
I had the exam two weeks ago, and I'm waiting for the results... And I'm really not confident about the outcomeSmiley Indifferent
Cheers,
Olivier L. | Certified LabVIEW Developer
Message 31 of 35
(1,507 Views)
Front panel is missing
Need to list all indicator properties! (ever think how much implicit code LV has?)
Is font Win 7 compatible?
Message 32 of 35
(1,457 Views)
Hello All,
Thanks for all the feedback on the sample ATM exam.
The sample ATM exam is a copy of a candidate's CLD submission and by no means this is the perfect solution - but it is a passing solution. In the candidate's evalaution, points were taken off for the making the VI re-entrant in addition to other minor issues.
I understand some people's passion in passing the failing verdict on the exam. But, we have to acknowledge, that there could be small but correctable shortcomings in the candidate's understanding. The exam's evaluation provided the feedback opportunity and the corrective learning experience.
As much as I would like to leave the sample solution as is, I also see the downside and (possible) associated risks. I will fix the solution and re-post today.
If you have any specific questions or comments. please email me at certification@ni.com
Zaki Chasmawala
Senior Engineer
National Instruments - Training & Certification
Message 33 of 35
(1,379 Views)
@zakic wrote:
Hello All,
Zaki Chasmawala
Senior Engineer
Thanks Zaki!
It's me again. Thanks for your active public support of the Certification program. You will add an asterisk and a link to this thread or a summary of such to help avoid an issue that drives me nuts that being "well I just coded it like the VI I downloaded from NI." I just want it to be clear that seeting it as reentrant was not correct and the only reason it worked was... fill in the blank.
again, Thank you!
Ben
Message 34 of 35
(1,373 Views)
@zakic wrote:
Hello All,
Zaki Chasmawala
Senior Engineer
Zaki - Brilliant IDEA-
Post the evaluation comments (sanitized of course) or a summary with comments.  This would be a Serious Improvent and help CLD candidates learn more about what to expect.!
Message 35 of 35
(1,352 Views)
