Fuse Design System Controls Font Size Limit
I am wondering if anyone has tried to use large fonts with the Fuse Design System numeric controls and run into an issue where the little arrow in the corner of the box will not disappear.  I am referring to the diagonal arrow in the lower right corner of the box that indicates there is more text than can be shown in the indicator/control.  It seems to happen when I try to use a font size of 40 or above. I am using LabVIEW 2023 Q1.
(838 Views)
Perhaps the font size is bigger than the height of the control?
Bill
CLD
(Mid-Level minion.)
(830 Views)
