Fuzzy Logic Designer not matching output given on front panel/block diagram
I am new to LabView and I am trying to use it for a Fuzzy Logic Controller but there seems to be a mismatch in values from the output given in the test system area of the Fuzzy Logic Designer and the numerical output calculated using my block diagram. I have checked it has the correct path so i cant understand why the two values would be different. Can anyone suggest why this might be?
(526 Views)
Here is a snip showing the test system result
and one of the block diagram
and the front panel which is showing a different value for duration
Any help would be appreciated.
Many thanks
(523 Views)
