Fuzzy Logic Toolkit Edit menu missing in labview 8
I've just installed Labview 8 and the edit menu for the Fuzzy Set editor is missing so you are unable to edit the Fuzzy Rulebase after it's initial creation.  The toolkit still functions correctly on 7.1.  Any help to get it working would be appreciated.
Message 1 of 8
(5,009 Views)
Have you tried re-installing the toolkit? Installing a new version of LabVIEW will not copy files from a previous installation. You should first check to see whether the toolkit requires an update before trying to re-install.
Message 2 of 8
(4,993 Views)
Yes I've tried reinstalling the toolkit, and have had no luck.  Labview 8 was fresh install on this computer rather then an upgrade.
Message 3 of 8
(4,985 Views)
Hi Kevin,
This issue has been reported to R&D under Corrective Action Request number #3SF7IEJ6 for further investigation.  Please contact us by sending an e-mail to support@ni.com and/or by phone as we would be happy to assist you. Thanks for the feedback!
Best Regards,
Steven B.
Applications Engineering
Message 4 of 8
(4,971 Views)
Having the same problem with LV 8.0.  I can't edit is at all after initial creation.  The software seems a bit old and really needs an update.  Just running the program by it self uses 50% processor because I think it is polling the buttons and not using events.  I will try to load it under 7.1.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
Message 5 of 8
(4,923 Views)
Found the patch
[link removed]
Matthew Fitzsimons
Message 6 of 8
(4,918 Views)
I have the same Problem now because i am doing my Bachelorthesis in a firma in germany and i have to programm
a fuzzy Controller.The Fact is that the Edit Set menu or the fuzzy set Editor are missing.
I use the Version 8.6. Can you help me please?
Message 7 of 8
(4,351 Views)
Hello all
The PID and Fuzzy Logic Toolkit 2009 was completely redesigned.
There are new API VIs and a more intuitive user interface for creating controllers.
You can create MIMO controllers with unlimited inputs and outputs, and also modify the controller on-the-fly.
Check it out the new features and let us know your needs on Fuzzy control.
LabVIEW PID and Fuzzy Logic Toolkit User Manual
Bruno Cesar
Message 8 of 8
(4,157 Views)
