Fuzzy System Designer Vi has broken arrow, no error
Hi guys,
Have this weird problem with Fuzzy System Designer, it stopped working properly, it has broken arrow when I open it, does not allow me to add inputs/outputs, or rules. When I click to check what errors cause broken arrow, it shows no arrow. I tried to force it to recompile, pressing Ctrl+Shift and clicking on arrow, nothing changed. I have no idea what could have possibly happened to this VI and why it is not working. Can anyone explain this to me? Or send me a copy of that VI for 2015 LabView so i can try to replace it?
Best wishes,
Masha
(3,787 Views)
Is this the Fuzzy System Designer you find from the Tools menu?  That's showing up as a broken VI for you?  After you click the broken run arrow, the arrow disappears instead of giving you the error list?
(3,747 Views)
Please try to stay on the same thread and avoid creating duplicate posts.
http://forums.ni.com/t5/LabVIEW/Fuzzy-System-Designer-PID-error-does-not-open/m-p/3257179/highlight/...
Barp - Control, Simulation, RTT and HIL - National Instruments
(3,739 Views)
Hi. It opens regular error list window that states no errors. After I close the window broken arrow still is here.
(3,709 Views)
