Fuzzy System Designer
Im working on my thesis, where i have to use fuzzy. I set pretty much everything from variables to rules, but i dont know why my test system is not showing output values 100 when every variable is set to the highest value, i tried to change defuzzification method, but only Center of Area is showing the output values on 93,75 and its the highest point it shows. Could you please help me or recommend me how to fix it?
I attached the file .fs
Message 1 of 1
(2,010 Views)
