Fuzzy controller file (.fc) does not open on another computer
When I create my .fc file on one computer and try to open it on another, I get an error that says the file cannot be opened, and so I have to create the file again on that computer. What may possibly be the problem?
Thanks.
(2,774 Views)
sima,
The only thing I can think of is that you may be using two different versions of the Fuzzy Logic Toolkit. Version 5.0 was a stand alone toolkit. Version 6.0 comes with the new PID 6.0 Toolkit. There may be file incompatabilities that you have found. Is this possible? Or are you using the same toolkit version on both machines?
Also, what operating system and version of LabVIEW are you using?
Randy Hoskin
http://www.ni.com/ask
(2,774 Views)
I re-installed the same toolkit on both machines and that did the job. Thanks!
(2,774 Views)
