Fw: Digital waveform question
I want to show several (say, 3) independent boolean plots in one graph.
How can I do it ? In the examples I've found only 8 / 16 or 32 plots,
representing bits of a given byte / word or double word.
Thank you,
Sergey.
(2,921 Views)
You have to convert the Boolean array to an array of numbers using the 'Boolean to (0,1)' function. The attached VI shows how to do this.
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,921 Views)
The plain digital data can be clustered with a mask to define custom groups
or digital lines for a plot. The Example Digital Graph Mask.vi should give
some info.
Greg McKaskle
(2,921 Views)
