G Toolbox 3.0 is available
G Toolbox 3.0
[New VIs]
Delete Menu Item Delete the Item on the menu of the specified window.
Disable Menu Item Disable the Item on the menu of the specified window.
Enable Move Window to Top Enable "Set Foreground Window" to bring window to top.
File Download Download the file at URL.
Is Mouse Installed Determine if a mouse is installed.
Listbox Create a window object, listbox, on the parent window.
Support drag & drop.
Lock Screen Lock screen, protect your PC from unauthorized use.
Monitor Shutoff Shutoff monitor. Save screen, & doesn't consume CPU time.
Scrolling Text on Titlebar Scrolling text smoothly on titlebar.
Set Child Set parent/child relation, confine child to parent panel.
Shortcut Info Get .lnk
parameters.
Show Image Support bmp, jpg, wmf, emf, ico, etc.
Skin Set the background of the front panel. User can change
the skin dynamically by Drag & Drop.
SysTray III Support popup menu.
Window Sizing Event Tracking window sizing event.
[Revised VIs]
BMP Shaped Window Better perfermence.
Drag Object Using mouse move event to update the object position while
moving.
Drive Info Support size > 2 GB.
Load BMP to Clipboard Preserve original color depth.
Save Pic Support 32 bit window.
Send Keys Support Window key.
Shortcut Support start direcity, & parameters.
SysTray & II Use titlebar icon as default if no icon handle specified.
[Examples]
DragDrop Listbox Demo
Scrolling Text on Titlebar Demo
Set Child Demo
Skin Demo
SysTray III Demo
Window Sizing Event Demo
Available in LabVIEW 7
George Zou
http://gtoolbox.yeah.net
George Zou
(3,514 Views)
Hello George Zou ,
I can not login your web site , would please advise me how to realize the drag and drop with LabVIEW ? Thanks .
David Lee
(3,514 Views)
Hello George Zou ,
David Lee
(3,514 Views)
David,
My web site address is:
http://www.geocities.com/gzou999/index.html
There is no login needed.
George Zou
George Zou
(3,514 Views)
