G -WEB- server
Hello.
I have a question.
I have LV7.1.
I 1 time run the G -WEB- server.
Then I closed it.
After I run Apache.
And when I type 127.0.0.1 in WEB brouser I see only first page G -WEB- server of LV.
What do I do?
Respect
Aleksandr.
(3,037 Views)
Hi Aleksandr!
Can you clarify what you are trying to accomplish with your application?  Using the G Web Server you can perform the following tasks with VIs:
• Run VIs
• Work with CGI applications
• Integrate with other computers
• Work on different platforms
• Implement security
• Publish front panel images
If you are trying to examine the online examples for the Internet Toolkit, you might have run into some problems configuring the G Web Server.  You must configure the document root directory properly.  You can refer to the Configuring the G Web Server section for more information about configuring the G Web Server on page 9 of 16
LabVIEW Internet Toolkit User Guide - http://digital.ni.com/manuals.nsf/websearch/253D7A7E8C2F6A4986256E1A0072FBFC
The manual was developed for LabVIEW 6.0 but I think it might still be relevant for LabVIEW 7.1,  I hope this information help.  Let us know if you have any problems.
Mark Walters
Application Engineer
(3,018 Views)
Hello Mark Walters.
Thanks for the attention.
Excuse me for the big delay with answer.
I think that I solved this problem thanks to Yours help.
Best regards.
Aleksandr
(2,968 Views)
