Hello Mohadjer
Thanks for the info.
I guess you are right, it is not possible to make a multiple calls to the same CGI.
One of the things, which has been mentioned in the thread and which I have been looking into is the template solution.
There is an example in G web server examples about that, but it will make the whole thing more difficult, especiallt that I use the client-server side cookies.
I have already checked that G web server will process simultaneously two different named vis, so the template sounds like a good solution for this. Of course, it could be better if user did not need to take care of this (as it is in other CGI servers). It could be actually the "show stopper" in my project.
kind regards
Pawel
